Flat Tire...suspension damaged?
madh83
149
So, I took a sharp turn too off the highway on the way to work with a new route in the morning on an 08 mazda3(leased). My driver side wheel hit nicked hte really low curb and it popped. I had to get a tow that told me not to take it to the dealer. I had my doubts about what he was saying at first, but I ended up believing him. I ended up having to call insurance because the wheel and suspension are damaged. It did seem like the axle was bent slightly, so I felt like they were being honest. However, I still feel like maybe I should've taken it to the dealer and explained the wheel should have never popped so easily in the first place. I've never even had an accident before , so I really don't know. So...did I make a mistake here??
Thanks ahead of time.
Sluggo
15,488
It really depends on how hard you hit the curb, did you "nick" it or really smack it.
madh83
149
Well, the curb was really low, no more than 2 inches above the ground with no fence. I recall nicking it, but I'm biased. Still I'm thinking even if i drove over it, it shouldn't have been that bad.
thomsbrain
18,148
If you run into a curb at full driving speed, you can expect damage to your car. Think of it this way: You crashed your car into a small wall.
summit
2,097
yeah my axle broke when i got clipped by a van and spun out into the weeds and jumped over the curb.
madh83
149
So I did the right thing by taking it to a repair shop right? I just keep thinking about it, sorry if I'm repeating myself.
Zenmervolt
Elite member
Oct 22, 2000
24,514
36
Most likely scenario is that if it was a front wheel you at least bent a tie rod end. That's usually the weak point. The axle is also possible to damage, so that's a valid thing to check. I think you did the right thing.
ZV
