Great forum for hardware.
I'm hoping you can help me. I am looking for recommendations for a 17" FP monitor to be used for 80% windows use (internet, word, e-mail) and 20% gaming. I want to connect using my Sapphire Radeon 9600 card with a DVI-I connection.
Will I be able to connect a DVI-D supported monitor using the included DVI cable? Basically is this DVI-I to DVI-D a standard connection?
What monitors should I check out? I'm seen reviews for Viewsonic VP171B, HP F70, CTX PV722E, Planar PL171M, Sony SDM-X72/B, Dell 1703FP, which all support DVI-D.
Thanks,
Mike
Thanks,
Mike
