Flashing a 48x24x48 drive to 52x24x52 drive
Today I got a "Khypermedia" 48x24x48 drive which resembles my old 40x12x48 CDRW drive. I think both are rebagged Lite-Ons because of their resemblance of one another from different companies and resemblance of pictures of the drives at newegg.com
How should I go about flashing the drive? I have no clue but I am searching on google incase my bad searching skills turn good for once.
Oh, and I know it won't make a big difference but it takes a few minutes to flash and I want to try it out since I have 52x media to use now.
You have to check, and confirm that its a Lite-on clone. Check your current firmware version with NeroTool, look at your exact model number, and then see if you can find any correlation between your drive and a LiteOn 40x12x40 CD-RW. LiteOne doesn't make 40x12x48 drives btw. Their 48x24x48 drive is the LTR-48246S, which is upgradeable, and the LTR-48246K, which is not. The LTR-48246S has firmware versions that look like SS0x, where x is a digit/alphabet. However, clone drives may have slightly different firmware versions. For example, my Iomega 48x24x48 drive, which is a LTR-48246S clone, had a firmware SOS2. It looks similar but not identical to the LiteOn firmware...I was able to flash it to the Iomega 52x24x52 firmware, which is another LiteOn clone.
For more information, check The Big Lite-On FAQ
For the firmware files, check firmware-flash.com
Good luck.
