flash point vs. boiling point
Discussion in 'Off Topic' started by IceBergSLiM, Oct 3, 2008.
  1. IceBergSLiM
    IceBergSLiM Lifer
    Jul 11, 2000
    29,953
    say i have 80 proof 40% alc/vol rum
    how do i determine flash point and boiling point?
  2. Fenixgoon
    Fenixgoon Lifer
    Jun 30, 2003
    24,890
    52
    the boiling point is when the vapor pressure of the liquid is equal to the atmospheric pressure. if i were really ambitious, i'd look it up in a thermo book, because generally it goes something like:
    ln(P) = A*T + B*ln(T) + C/T^2. you also have to account for the fact that you have a mixture (but it has complete solubility). so we'd use raoult's law and the other one, which i can't remember off the top of my head, heh.
    oh thermo, it's only been a year, but i've forgotten it all already :brokenheart:
  3. IceBergSLiM
    IceBergSLiM Lifer
    Jul 11, 2000
    29,953
    how do i figure that out for an 80 proof rum?
  4. IceBergSLiM
    IceBergSLiM Lifer
    Jul 11, 2000
    29,953
    yeah that might as well be chinese for mje what are p, a, t, b, mean?
  5. gorcorps
    gorcorps aka Brandon
    Jul 18, 2004
    29,908
    195
    80 proof rum means 40% by volume alcohol, which is ethanol. The other 60% is assumed to be water. Ethanol has a BP of 78.4°C and water at 100°C. You can use those temps and fractions to estimate the boiling point (with the assumption your atmospheric pressure is 1atm or 760mmHg(torr)).
  6. IceBergSLiM
    IceBergSLiM Lifer
    Jul 11, 2000
    29,953
    flashpoint anyone?
  7. Paperdoc
    Paperdoc Golden Member
    Aug 17, 2006
    1,525
    11
    You could try requesting an MSDS Data Sheet from a distiller. Those are the sheets that specify a whole bunch of safety-realted info, required in all industrial workplaces to ensure workers are aware of all hazards and safety precutions. They will ALWAYS specify the Flash Point if there is one, and many contain the boiling point also.
    I don't know if 80-proof alcohol has a Flash Point. That is the temperature for a liquid at which it will spontaneously burst into flame without exposure to a direct ignition source. While the rum may burn when lit with a match, that is not the same thing.
  8. Brainonska511
    Dec 10, 2005
    18,526
    248
    Even then, you don't need to estimate the boiling point, as the ethanol will hit the BP of 78.4C and start boiling off at that constant temperature. After the ethanol boils off, the temperature will continue to rise until it hits the boiling point of water. This is the general idea behind distillation (boiling and recondensing so that the alcohol ends up in greater and greater concentrations).
    As far as flashpoint, isn't that the temperature at which it will combust?
  9. darkxshade
    darkxshade Lifer
    Mar 31, 2001
    13,756
  10. Tiamat
    Tiamat Lifer
    Nov 25, 2003
    14,079
    4
    Um, flash point is completely unrelated to boiling point. Flash point is the minimum temperature required for the it to become ignitable in air.
    If you want to flash your rum, its not going to be very easy since its ethanol content is low. Pure ethanol flashes at 12.8 celcius. Flash point of 54% rum is about 22 celcius. Normal rum will be higher while Bacardi 151 will be in between 13C and 22C as you can see this trend...
  11. Itchrelief
    Itchrelief Golden Member
    Dec 20, 2005
    1,396
    I'm talking out of my arse here, but I would suppose it would have some relationship with the volatility of the flammable substance, since it is usually the vapors that combust.
    By wildly making assumptions, I would think you'd probably need to know the minimum % of alcohol vapors in air to sustain combustion, then find at what temperature you will get a partial pressure of alcohol that corresponds to that %.
    Assuming the above is true, lower boiling point means more vapors = lower flash point, assuming the combustion occurs at the same % of vapors in air.
  12. Tiamat
    Tiamat Lifer
    Nov 25, 2003
    14,079
    4
    see my edits.
    Alcohol won't behave linearly, however, a rough guess can be had with linear interpolation.
    Problem with flash point is the second you remove the ignition source, the flame goes away. If you want the flame to remain you have to reach the Fire Point, which is somewhat higher.
    For this reason, Bacardi 151 is relatively easy to keep on fire at room temperature conditions (while normal Bacardi rum is not as easy).
    If you want a more exact Flash and boiling point, you will need a chemistry lab and learn rudimentary thermodynamics through wikipedia.
  13. olds
    olds Elite Member
    Mar 3, 2000
    48,767
    58
    MSDS?
    EDIT
    Guess they don't have them for "food".
  14. IceBergSLiM
    IceBergSLiM Lifer
    Jul 11, 2000
    29,953
    f that shit. lol
  15. Tiamat
    Tiamat Lifer
    Nov 25, 2003
    14,079
    4
    If you have some extra rum why dont you just try the experiment?
    All you need is a thermometer, and a heat source.
    1. Put rum in cup with thermometer.
    2. Keep fire extinguisher very close by
    3. Test rum at room temperature with a lighter. Did it light? (Yes/No). If not, increase temperature.
    4. Record the temperature that the rum flashed.
    5. Record the temperature that the rum started boiling.
    6. What did you learn from this experiment?
  16. Eli
    Eli Super Moderator<br>Elite Member
    50,432
    The boiling point of ethanol, as someone mentioned, is 173.1ºF.
    The flash point of 40% ethanol/60% water is 78.8ºF.
    That's probably close enough for your rum.
  17. Tiamat
    Tiamat Lifer
    Nov 25, 2003
    14,079
    4
    Seems reasonable compared to linear extrapolation from the data I supplied earlier.
  18. IceBergSLiM
    IceBergSLiM Lifer
    Jul 11, 2000
    29,953
    so buy your calculation if I'm drinking rum on a hot summer day its going to explode?
  19. DisgruntledVirus
    Dec 26, 2007
    11,790
    With an ignition source it could ignite and burn, but not explode. The flash point is not the temp where a vapor will explode, but instead where it will ignite. It may or may not continue burning when the ignition source is removed.
    per wiki
  20. IceBergSLiM
    IceBergSLiM Lifer
    Jul 11, 2000
    29,953
    sorry guess I'm confusing flash point with auto ignition point
  21. RapidSnail
    RapidSnail Diamond Member
    Apr 28, 2006
    4,258
    No. The liquid must be 78.8ºF for it to be ignitable. How many people drink bear at ~80 degrees on a hot summer day?
  22. DisgruntledVirus
    Dec 26, 2007
    11,790
    I want to know how many people drink bear
  23. alkemyst
    alkemyst No Lifer
    Feb 13, 2001
    83,988
    8
    guess it's the same with push and pull with you.
  24. RapidSnail
    Apr 28, 2006
    4,258
    Oops. I should have said "bare." Which might make sense! :laugh:
  25. Paperdoc
    Aug 17, 2006
    1,525
    11
    Bear Beer, etc.:
    http://en.wikipedia.org/wiki/Hamm's_Beer_bear
    http://beerblog.genx40.com/arc.../january/stoutsbigbear
    I am having difficulty in accepting the idea that at 80F a glass of plain 80-proof rum (or other liquor) will spontaneously flash into flame, even if it quickly stops burning without a nearby ignition source. I expect the temperature to be much higher than that.
