flash or coldfusion....
cmdavid
4,114
Which one would you experts recommend I learn first?? And how would you recommend I go about learning how to do it??
Reason I want to do it is just because when I see cool flash pages and coldfusion pages like rh71 I am awed and wish that was something that I could do.. any advice is welcome... thanks all..
gopunk
29,239
cfm is a scripting language, and flash is... vector animation. i don't think they're that closely related, but maybe i'm wrong.
Nocturnal
18,927
i vote for cf. this forum is created from cf. its awesome!
btw, is cf heard to learn? is it similar to html?
cmdavid
4,114
<< cfm is a scripting language, and flash is... vector animation. i don't think they're that closely related, but maybe i'm wrong. >>
really?? I always thought they were closely related.. maybe I'm just retarded though.... somebody recommended to me to learn CF if you dont want to spend as much time designing... I'm not sure though, as I dont know either...
ElFenix
102,393
8,552
cf is a database driven front end... similar in function to php as i understand it... flash makes pretty moving animations...
VirusDub
1,111
The only way they're related is that they're both owned by Macromedia. ColdFusion is used to integrate a database into your website or perform operations on user input. Flash is used to create animated (or otherwise artistic) components or entire frontends for your website. The two can be used in conjunction, but they are quite distinct.
