- Feb 25, 2004
- 21,758
- 603
- 126
So flash drives are kind of a mess. Their actual read write performance is all over the place, the rumor is they use the worst available memory they can get away with, amazon is overrun by counterfeits.
I recently bought this guy: https://www.amazon.com/RIITOP-Docking-Station-External-Adapter/dp/B089JXSMB8 and it worked pretty well, at least with the low end drive I installed in it. It uses some jmicron controller, should work with nvme or SATA based m.2 drives, it looks kind of bare bones and I wish it had a power switch but nbd. There are of course a lot of different m.2 USB adapters of varying quality. It performed a lot better than my crappy USB flash drives though.
Then I looked at prices and saw that there really isn't much difference between a 256GB flash drive and a bottom tier m.2 drive in price. But even a bottom tier m.2 seems like it will have far fewer fake problems and far better performance than your average flash drive. And decent OEM drives like sk hynix don't go for more than a few bucks extra. They are about the same size, larger but not much different. So I was thinking maybe I'm going about it all wrong...why don't I just buy m.2 drives instead of flash drives.
Obviously the main problem is the extra cost of the adapter and that m.2 is only rated for 250 insertion cycles (it is an internal interface after all). Am I missing something else though? Because flash drives can be brutal on writes.
