Flash Cache Module. How important?
Compman55
1,241
On a dell laptop, how important is this to be enabled? What kind of real world speed do I gain from having this?
corkyg
Elite Member | Peripherals
27,370
239
AFAIK, FCM was designed to be used with Vista to enhance ReadyBoost. It does not work in XP. Don't know about Win7. It depends on your OS.
fuzzymath10
520
It's for Intel Turbo Memory. You need to actually have the mini pci-e flashcard in the slot; the BIOS setting simply permits detection. There's a driver for Vista and Windows 7.
If you have a Santa Rosa chipset (Latitude D series) it's pretty useless. If you have a Montevina chipset (Dell Latitude E series or newer), you can not only use larger cache modules, but have user pinning which allows you to choose which programs will remain in the cache.
I just did away with it and bought an SSD; this was meant to be a stopgap.
