Flash 9800np --> 9800 pro. Current information?
TSDible
1,697
Hey all...
I know this is kind of old news, but I wonder if anyone has some current information on flashing the 9800np to pro. I have a 128MB NP card with Samsung ram, and I'm looking to extend its life a bit.
Cany anyone point me to a site that has a current bios and flashing information?
I did a search of the form and googled it, but didn't find anything of use.
Any help is appreciated.
TIA
Marsumane
1,171
Just a tip for the future:
when u have this case, search anandtech forums for your answer. i just found many threads dealing with this issue. :)
TSDible
1,697
Yes, I found all of those as well. I was just wondering if there was any more up-to-date info out there. All of what I found was a bit dated.
It doesn't seem that much has changed since then though.
blazerazor
1,480
dude, those cores overclock like mad but the memory on mine would only get like 10or15 mhz overclock. Good luck.
Matthias99
8,808
Flashing the BIOS on a 9800NP, AFAIK, does very little for you, as the only difference between a 9800NP and 9800Pro is the clocks (although sometimes the higher-end cards use different memory timings and things like that, but the performance differences are usually very minor). You might as well just OC your card.
