Originally posted by: Jeff7
For my FLAC to MP3, I use CDEX and a file renamer named Siren.
I'd like to post this at theCDex forums, but I can't seem to register - the confirmation e-mail never arrives, and the e-mail to contact an administrator leads to a nonexistant domain.
Anyway, there's a FLAC plugin for Winamp. inflac.dll or something like that. Copy it to CDex's Plugins folder. Start CDex. Set it to recompress compressed files. You can use the Encoder properties to set the bitrate and whatever else you want.
That'll create a bunch of files looking like this:
song title.flac.mp3
Use Siren then, and set the Expression to this:
%b(".flac","").mp3
It renames your files, and you're left with good MP3 files. A bit more complicated than it should be; if CDex's developers ever add official FLAC support, this'd all go away. But it works, and it does so without needing to pay for anything.
Also, someone mentioned dbPowerAmp requiring money for MP3. Easy way around that. When you download LAME, there's a folder called ACM in the compressed file. In that is LameACM.inf. Right click, and select Install.
Now, back in dbPowerAmp, set the output to WAV. However, select Compressed, and then click Change Format. In the new window that comes up, scroll through the available compression options. Lame MP3 should be one of them. It lacks the extra options like the flags (private, copyright, and the CRC option) but it works. For free.
