Started to get a spot in the ceiling in front of the chimney, so I went up into the attic to look. There are a few slowly dripping leaks along with width of the chimney.
On the roof the shingles look ok above the chimney, and the flashing at roof level does not have obvious problems. The "caulking" at the top of the flashing is highly fractured and falling out. Is this likely the failure site? This is also the side facing the wind/rain. I have a tube of Black Jack Rubr-Seal roof & flashing cement. Should I remove the broken "caulking" and fill that area with this? I don't want to screw up a permanent repair if for whatever reason this would not be considered permanent.
The roof pic is from yesterday which is why it's dry.
