fixing drain in tub
CasioTech
7,145
9
I know that I need pliers handles down and then use them as a wrench... Is there any advice? I changed the one in my kitchen sink as well and that was pretty easy... I know that the bath tub can be tricky.
35,559
Isn't the drain supposed to leak?
Anyway, where specifically is it leaking? Do you have teflon plumbers tape handy?
NoShangriLa
1,652
Not much different than kitchen sink, however it can be difficult to take the flange off the tub. Try using a pair of pliers to take it off, other wise a basin/strainer wrench might be a requirement (a piece of pipe with 4 cut slots with drill holes for screw drive leverage will do it in a pinch). Dill and use a chisel/screw drive to hammer it out if rust seize the flange in place. Plumbers puddy or silicone caulking often is use between the flange & tub for a better seal.
CasioTech
7,145
9
wait.. In the crosshairs of the tub drain, I bought a washer I think it's the problem. I know to silicone everything as I did in the kitchen, but when I try to unscrew the drain it won't budge... I am afraid if I do it too hard I will crack something..
NoShangriLa
1,652
Not much different than kitchen sink, however it can be difficult to take the flange off the tub. Try using a pair of pliers to take it off, other wise a basin/strainer wrench might be a requirement (a piece of pipe with 4 cut slots with drill holes for screw driver leverage will do it in a pinch). Dill and use a chisel/screw driver to hammer it out if rust seize the flange in place. Plumbers puddy or silicone caulking often is use between the flange & tub for a better seal.
As indicated above, tub flange tend to seize due to built up & rust, therefore harsher method may required. Try to break the seize wit a hammer & screw driver/chisel/counter sink punch then use a basin wrench to remove it.
