We have a break in the invisible dog fence that I'm trying to fix. I found this on the intranetz:
http://blog.paulasgriffith.com/2007/03/
I bought an RF choke #273-102 which is 100 microhenries +-10%, 2amps max, rated at 1kHz. I unplugged the boundary/fence wires from the transmitter and put one lead from the choke in one terminal/plug and put the other RF choke lead into the other terminal that used to grab onto the boundary/fence wire. I then took the boundary/fence wire and connected it to a lead of the choke. After tuning my radio to 600 AM and I got nothing.
Any ideas what I'm doing wrong?
Method #2: This method requires you purchase an "RF-Choke" from Radio
Shack (Catalog item # 273-102) and use an AM Radio. Once you have these,
follow these procedures:
1. Disconnect the boundary wire from the terminals on the transmitter.
2. Wrap the boundary wire around the choke leads
3. Connect the choke leads to the terminals on the transmitter. The
choke has now completed the loop as far as the transmitter is
concerned.
4. Turn the range adjustment knob up 1/4 to 1/2 turn.
5. Take the transistor radio and set it to AM 600. Stand outside the
structure where the twisted wire exits and listen for the
pulsating static of the transmitter.
Gently swing the radio back and forth across the front of your body and
follow the wire out to where the loop begins. Pick either direction and
continue until the pulsating stops for a 4-6 ft area. In this area is
your break.
That's what we did. We got pretty good at it!
