- Feb 2, 2005
- 17,252
- 19
- 81
So I was installing a new Heatsink and Fan in my HTPC. The orientation of the MB and the way the fan overhung those damnable Intel pushpins (for securing the HSF to the MB) necessitated the use of a screwdriver to actually apply the pressure to two of the pins to get them to snap in place. Needless to say my screwdriver slipped off of one of them and put a barely noticeable scar on the board near the CPU socket. It didn't look like it actually went deep enough to sever any of the wires running through the board, so I figured I had dodged a bullet. I was rather put off by the lack of posting I got when I fired the machine up.
The diagnostic LED readout was hanging at C1, which I found out was "memory presence check". Going off that I removed all the memory except the stick farthest from the CPU slot and tried again. It booted up fine this time. It also booted up fine with a stick in the second to farthest slot from the CPU. It does NOT post with a memory stick in either of the two closest slots, hanging at C1 once again. I've tried all the sticks of memory I have in every combination of slots, cleared the CMOS, etc. My only conclusion is that I have rendered two of my memory slots useless. Worse, the motherboard uses staggered slots for dual channel operation, so I'm running on single channel only. This is unacceptable.
Or maybe it's not the scar that's the problem? The only out of the way thing that happened was the screwdriver scratch, so I'm assuming that but I'm open to suggestions. If it is the scratch, is there any method I might use to fix it? Or should I just replace the MB?
