Hi.
When i was working in my PC a few mins ago, on the mobo end of the IDE cable, the thing that holds the wire in, that has the pins that poke through the wires, came off.
I carefully put it back together, with the pins going back into the wires at the same place.
Now, the cable still works, should i be worryied about anything? Or will it be ok?
Should i buy a new cable just to be sure?
