Ok here is my situation. One of my employers has an AMD X2 3800. When he first got (a while back) it had a bent pin. He tried to return it to newegg but they just sent it back to him. Now he might sell me this processor REALLY cheap becuase he doesn't know you can fix bent pins. Do you think it would be worth the risk and try to fix it? I would want to look at the proc first but is there a way I can tell if it's a bent pin or something more serious? Pics would be great if anybody could find them. thanks a lot.
UPDATE:
He gave me the proc for free. Now when I looked at the pins I see ONE blent pin. So it looks like it might be fixable. He said he took it to a PC place and they could not get it to work on any system. But if that place knew anything about procs, they would have tried to fix this pin. The only other problem I see is that looks like some thermal paste got on two corners on the proc, no pins have paste on it. Is there a way to clean it off? Thanks a lot!
UPDATE:
