Fixed: Yeah, not happy with this HD6950 (excessive heat with multimonitor problem)
Status
Not open for further replies.
jackstar7
11,679
1,944
These kind of posts dont surprise me. I had my hell for almost 4 years with ati x800 xt pe
The hell is not in the hardware but in the buggy software. ATI cant make drivers and they never could even with the all in wonder you get desktop corruption. CCC installs sometimes other times it doesnt,, just a bi*ch. One driver your card is fast other driver things are slow slow.. I never will trust AMD ATI ,, Grab a nVidia card next time and you wont have these problems. Other then that RMA the card. gl
Or this issue exists for both companies. It's about mixed res monitors.
So by all means, get an nv card and experience the lack of a difference.
evolucion8
2,867
That's odd. I've never experienced any driver issues with my Sapphire Radeon X800XT PE. Previous AMD architecture like X1K or older had little dependency in driver optimizations to perform optimally.
Elfear
7,126
738
Same here. I loved my X800XT PE and associated drivers.
SirGCal
122
www.sirgcal.com
I hate to say it, but that's really about the worst fanboy-type post I've ever seen. Both cards have their huge share of problems. For a while it was nVidia, then AMD, then nVidia, then AMD again... To say one is truly better than another by a landslide just isn't true. I've used both since their origins. Both have their share of problems. Both have their share of driver-specific problems to boot. Plus, the 69xx series is a new chipset. Not a hyped-up 68xx chip. These chipsets require specific considerations when writing drivers on both sides. To be honest, the AMD programmers had the real chips for so short a time to test, I'm amazed they are as stable as they are. I've yet to have a single problem.
But saying one manufacturer sucks at coding drivers just cause you had a dud card is pretty silly. And I'm sorry but if you had that much of a problem, you had a dud card and didn't fix it. I had multiple X800's myself and one was an issue also while the others were peachy-keen. The reason is most often; The designer is not responsible, nore can plan for, manufacturer's not following the reference design. We, as consumers, tend to like this cause that usually means better coolers and/or capacitors or something, but that also means they aren't necessarily following the rules set forth by the manufacturer. This was a huge issue on both sides back during that time. Today is still an issue but much settled.
Especially on immature products, both sides often have driver hickups... Very recently, nVidia had a problem so bad that it was literally causing damage to cards when they seriously overheated with their 196.75 version. And historically, both sides have ups and down. Not long ago, consensus was the other way around. I actually found a while back showing how bad nVidia's drivers were in the 2007 era.
http://www.engadget.com/2008/03/27/nvidia-drivers-responsible-for-nearly-30-of-vista-crashes-in-20/
http://arstechnica.com/hardware/new...it-paints-picture-of-buggy-nvidia-drivers.ars
Now still this was an OS with it's own host of problems... and I wouldn't by any means trust these numbers for true responsibility... But it is interesting.
discy
9
However. The XFX 6950 (unlocked to 6970) I had before was quite loud and noisy at 30% fanspeed. Now I've got one from Sapphire and I can barely hear it at the same fan-speed.
So. Conclusion: Don't buy XFX. They are noisy. Instead buy Sapphire or some other brand.
Grtz.
jlooooooooo
Banned
Jan 4, 2011
12
Thermaltake never could make good liquid cooling but you still seem to think they're great. Hypocrite.
Vdubchaos
10,408
10
I don't understand this entire drive argument.
Past 10 years I've had all kinds of Nvidias and ATI cards and I have never had any issues with ANY. And if I did I was able to research and figure out pretty easily.
I don't get it.
WelshBloke
31,408
9,300
Can we not make this into a who has the worst drivers thread as thats nothing to do with the topic.
I have managed to downclock the card with two monitors attached and get the temps under control.
I'll post back with the details soon as I'm a bit busy right now, but it isn't that complicated.
evolucion8
2,867
Well. To answer my own question: can you lower the gpu/memory clockspeed of the 6950/6970 when having multiple monitors attached? (To make it cooler and more quiet).
Answer is: YES. (i just did it). but NO it won't affect the temperature.
I'm able to go to a minimum of 345mhz instead of 500, below that the card shuts down. I could get my memory clock to 800, instead of 1345.
But lowering any clockspeed doesn't affect the temperature at all at least not when having multiple monitors attached :confused:.
Apparently the high temperature is caused by something else than gpu clock speed. Maybe core voltage ore some other thing. Also the fanspeed remained 30%.
Grtz.
That's interesting, lots of people are complaining of the same issue with XFX HD 6970 cards, it might be a setting on the BIOS level. And the most strange thing is that all the stock coolers used on the HD 6970 are the same. Mine is very quiet and even on full load, never exceeds the 40% fan speed, after that, it gets noisy.
Skurge
5,195
What did you downclock the card to?
discy
9
could be the bios. or maybe they use a bad thermal compound. It was not really an "blowing air" noise. But more an annoying sound.. like uhm. when the wind is blowing around your house really hard.. that kind of sound; but constant.
WelshBloke
31,408
9,300
I think its just that noise is very subjective, I find the fan at 40% really annoying. Definitely the loudest thing in my computer.
Opps mines a 6950, do they use the same coolers?
WelshBloke
31,408
9,300
Right very quick follow up then I have to go.
Cat 10:12a hotfix linked earlier in the thread.
Ticked enable overdrive.
Installed afterburner 2.1.0 beta 5.
Leave the core clock alone, dial down the memory as low as you can go without corruption (mines 675) this automatically drags the core clock down to 250. (bolded is where I was going wrong earlier).
Set up your auto 2d/3d profiles in afterburner and set up a fan profile that cools but doesn't annoy you too much.
You will have to mess around with the rivatuner stats server to remove some apps being falsly flagged as 3d when they arnt. (click on the i on the upper right of after buner and check the active 3d process line.)
Good luck.
WelshBloke
31,408
9,300
This seems rather pertinent to the thread: http://www.legitreviews.com/article/1461/19/
I'm still not certain why they do it though.
It mentioned both the monitors running at different timings causes it but if you can force different clocks using 3rd party software why cant NV/AMD do it in their drivers?
The comment from NV stating its a hardware problem not a software one is weird as the software controls both the clock speeds and fan speeds.
discy
9
  1. Cat 10:12a hotfix linked earlier in the thread.
  2. Ticked enable overdrive.
  3. Installed afterburner 2.1.0 beta 5.
  4. Leave the core clock alone, dial down the memory as low as you can go without corruption (mines 675) this automatically drags the core clock down to 250. (bolded is where I was going wrong earlier).
  5. Set up your auto 2d/3d profiles in afterburner and set up a fan profile that cools but doesn't annoy you too much.
  6. You will have to mess around with the rivatuner stats server to remove some apps being falsly flagged as 3d when they arnt. (click on the i on the upper right of after buner and check the active 3d process line.)
Good luck.
yay. tnx :)
I also disabled DXVA- and Flash-acceleration because the GPU would speed-up whenever such a technique was used. Although afterburner did not see it as a 3D-program.
before: fanspeed 30%, temp 60
after: fanspeed 26%, temp 51
Sapphire 6950 unlocked to 6970 - 3x 1920x1080
digitaldurandal
1,828
This gives skewed results. The company with larger market share is going to cause more problems.
discy
9
You mean like Microsoft with 100%?
? joke? not all vista crashes are due to Microsoft.
The amount of vista machines equipped with ATI or NVIDIA cards does influence the percentage of total vista systems crashing by either company.
If only 100 persons have an ATI card and 500 persons have Nvidia. There is more chance for an Nvidia crash than ATI. You would have to know the total number/percentage of Nvidia and ATI equipped machines in this test in order to make an calculation which GPU brand is more or less likely to crash.
I'm not an statistics master.. but I think it works that way :p.
Skurge
5,195
What about Intel then?
evolucion8
2,867
Well that's not true, Intel has the biggest market share in graphics and yet, with their twitchy driver support, had less issues than nVidia.
Status
