FIXED: This is the most rediculous excel problem I've encountered. Need help within 20 minutes.
fuzzybabybunny
Moderator<br>Digital & Video Cameras
Moderator
Jan 2, 2006
10,455
35
Every number I enter turns into a decimal.
16 becomes 0.16
142 becomes 1.42
I go to format cells -> number and the general number format is selected.
What the heck....
fuzzybabybunny
Moderator
Jan 2, 2006
10,455
35
It's already in the "general" number format, so when I enter "16" it should appear as "16."
fuzzybabybunny
Moderator
Jan 2, 2006
10,455
35
Originally posted by: HomeBrewerDude
whats the content of the worksheet?
check your pm.. you can send me the file if you want
The contents are just mock business data for an excel class.
When I enter "16" it autoformats to 0.16
When I enter 16. (with the decimal point after 16) it stays at "16"
KLin
30,859
1,003
chekc your settings:
Tools> options> Edit > Fixed Decimal Places should be UNCHECKED.
I concur with HBD.
fuzzybabybunny
Moderator
Jan 2, 2006
10,455
35
Yup, it worked. I just have absolutely no idea how it got that way. I was editing a spreadsheet and it was fine. After I got done and saved/closed it, I opened a new spreadsheet, and then the problem started appearing :confused:
DaveSimmons
40,730
670
Blackouts, fixed decimal places -- sounds like it's time for you to cut back on the drinking.
EvilYoda
21,198
9
yeah seriously...when I started getting fixed decimal places, I had to sit myself down and reevaluate my lifestyle.
fvcking decimal places.
