-- new topic
New keyboard works great! Now, how do I fix the WiFi?
I plan on using the laptop as a headless unit, by removing the display bezel top/lid and using an external monitor just via regular USB cable or HDMI.
I cut off the wires (black and white) from the antennas that were attached to the laptop bezel.
1) Are both wires for the WiFi antenna?
2) Is there something that I can wire to it to boost the signals?
-- old topic fixed
Broken ZIF or Broken Laptop Keyboard? Or both?
In the image above, you can see that a piece of the ZIF latch is broken (along with that bent pin on the ZIF connector)
The keyboard also does not function.
However, I am not sure whether the keyboard is working, but the ZIF connector is broken, or maybe the ZIF connector is fine (and the keyboard is broken).
Or maybe both?!
Can anyone tell if having that missing piece from the ZIF latch (and that bent pin) would affect a keyboard? Should I risk buying a replacement keyboard and seeing if it works? Can I do anything to repair it (assuming I get a replacement keyboard), and tape it? TIA!
-- old topic fixed
Or maybe both?!
