Fix Window 9x .VXD BSOD, inside...
Halz
335
All installations of Win9x bypass the inclusion of several fairly important .VXD files related to the major devices in your system. In the place of these missing files, Win9x commissions vmm32.vxd, a .vxd we are all familiar with in the 'blue screen of death' situations. When installed, these files will provide a stability unknown to Win9x. To find which files are missing, from the "Device Manager", view the "Properties" of a device and click the "Driver" tab. From the "Driver" tab, click on the "Driver File Details...". Any files with parentheses around them are the missing files which need to be retrieved from the .cab files WIN98_47.cab and WIN98_48.cab for the standard Windows 98 CD and .cab files WIN98_53.cab and WIN98_54.cab for Windows 98SE. Once the files have been located on the CD, the files need to be copied to the c:\windows\system\ directory and c:\windows\system\vmm32\ directory. Once the files have been copied properly, you will notice that the parentheses will be removed.
...not only will it make the system more stable but it may also enhance your system's performance in benchmarks you judge your system by, for the most part.
jsm
Banned
Oct 11, 1999
971
Wow.. how did you find the time to research all of this? Do you have a job?
