- Dec 9, 2001
- 5,710
- 0
- 76
My sister has been driving our Sentra for the past 3-4 years. We bought it brand new and it's been paid off for 5 years at least. Has 118k on the odometer.
Problem: It started having starting trouble a couple of weeks ago. No check engine lights. Sister took it to a shop, didn't find any problems. A few days later the CEL came on, and she took it to a stealership. They told her that they found some coolant in the #4 cylinder spark plug hole and the idle air valve is malfunctioning. They supposedly checked compression, but I didn't remember to ask what the values were. $1800 to fix it all + $150 diagnose fee.
I told her to take it to another shop to have a 2nd opinion. She took it there and the guy said he checked smog levels and found HC in the engine bay, and the exhaust does have some coolant in it. The mechanic said the diagnose was free since it was her first time there, and he actually suggested that she trade the car in and buy a new one since it still runs! His options were:
Replace head gasket, about $900.
Replace engine, about $2200.
They said the cylinder head has to be sent out for inspection, ok, fine, reasonable. But then he also said the head could be cracked, or even the engine block could be cracked, and we'd have to put a new motor in anyway in that case. I asked the mechanic if they did a compression test but he said it doesn't always find the leaks.
OK, so I'll be up front and say I'm biased, since it was my first car out of high school... Car has never been overheated when I drove it, and I'm pretty sure my sister didn't overheat it either. What would you do in this case?
