DaveSimmons
saw this linked to on Toms, thought it might help someone:
Tech-report.com
Tech-report.com
Here's the answer I got from Robert Pearce, Corsair's Applications Specialist:
Scott:
The problem is the chipset won't handle a tRCD (RAS to CAS Delay) of 2. We've done a revision of the SPD to make the LL's work on the 875 and 865 chipsets, the settings are now 2-3-2-6 by default.
We will, of course, warranty any modules with the older SPD but it should be noted that the end user can simply manually adjust the BIOS to the settings noted above
