Discussion Fix Door Misalignment Issues Once And For All!
Status
Not open for further replies.
Djsi222
Ever had a door that wouldn't shut properly due to slight latch misalignment?
Well, check out my kick starter project to solve this issue once and for all in a cost effective, quick, no-skill required way!
-- Link Removed --
Kickstarter links are considered self-promotion and not allowed in the forums.
Daveybrat
AT Moderator
Sgt. York
798
209
Living in a very old house I have had this problem many times. My solution wasn't to reinvent the wheel, but use what is already available at any hardware store. Simply install an oversize striker plate at a cost of about $3.50 US. It accomplishes the same thing without having to pay $50 US and replace the entire door latch. You're looking for a problem where it doesn't necessarily exist.
Also, you will never get a patent on your idea.
Greenman
22,266
6,445
Moving a strike plate isn't a real big deal. You can even use a dremel to grind it out if you don't want to move it.
herm0016
8,516
1,128
i used a hinge router template and just took a big chunk out of the jamb. made a new piece to fit, re drilled all the holes and chiseled out the mortise for the strikes. looks like new, and does not compromise security. i would not use this as it decrease the amount of metal you have hitting the strike and the wood behind it. I like to embed steel angle in the edge of the jamb when i install from scratch though. screwed into the wood and then a couple long screws from the face of the jamb into the stud through the angle.
Micrornd
1,361
227
Not to offend anyone, but this fellow works as an engineer for Ford's.
I have 2 brother-in-laws that are engineers, 1 still working for Ford's and 1 retired from Ford's.
It always struck me as strange that they would come up with solutions to problems that didn't exist or overly complicated solutions to simple problems.
Maybe it's the company work environment that causes it ?
Reactions: Thump553
snoopy7548
8,256
5,330
Some engineers love to create problems and then come up with complex solutions to them. Working with them is infuriating.
NutBucket
27,151
635
It depends on how anal you are. As an engineer there is a definitely a fine line between elegant solutions and solutions to problems that don't exist.
PowerEngineer
3,606
785
Applying science/technology to solve problems in the most cost effective way is pretty much the definition of good engineering. As is true in every other vocation, not every engineer is good at it. ;)
Status
