Get a scale that includes body fat. Uses Electrical impedence or something like that. It fluctuates a bit depending on water content in your body etc, but you get an idea within a percent after measureing several times a day.
Scale costs about 40-60 dollars where we got ours (wedding gift)
The less-accurate informal method: There's a freeware program out there called WinFAT that calculates it based on tape measurements of the neck and the stomach.
