First try at cable management :\
Ballashoes
15
Didnt really do anything special but whatta guys think. I have no room behind my mobo and the other side of case to put wires. Do you have any other ideas I could do to clean it up even more?
Before.
http://i44.photobucket.com/albums/f5/Ballashoes/Case/1.jpg
After.
http://i44.photobucket.com/albums/f5/Ballashoes/Case/2.jpg
http://i44.photobucket.com/albums/f5/Ballashoes/Case/3.jpg
http://i44.photobucket.com/albums/f5/Ballashoes/Case/4.jpg
http://i44.photobucket.com/albums/f5/Ballashoes/Case/5.jpg
swtethan
9,071
also maybe change your HDD to a 5.25 bay, the adapters are like $5 and they would be easier to cable manage since the hdd and cd drive is so close together.
move the cd drives down one so you can save space above to shove some cables there, you got a lot of slack.
aigomorla
21,134
3,673
Not as bad as mine
ahahaha.. but then again, its the tubes that are seen more then the wires.
But anyhow op, its a start to a good job. Like someone suggested, i would route the cables from behind. Thats the only way i could mount my reservoir. :p
