Question First time pc Build need advice
Oxide-
Hi im trying to build my first pc and im in need of some advice regarding the parts i have chosen. My budget is around 1k-1,2k and i intend to use it for Adobe apps, editing , stuff like that and casual gaming like battlefield insurgency fallujah etc im not a "High demand" gamer 60 fps is good enough for me. But Considering this is my first time i would like If you can tell/give me any pointers and advice on what i picked out and how good it would work i intend on upgrading in the future but i would like a decent enough desktop that would do well with tasks. Here are the specs:
Processor: Intel® Core™ i3-9100F 3.60GHz
Motherboard: MSI MPG Z390 GAMING PLUS
Memory: 2x 8GB DDR4-2666 XPG GAMMIX D30
Graphics Card: AMD Radeon® RX 560 4GB
Operating System Storage: Seagate 500GB 2.5in SATA3 BarraCuda SSD
Cooling Solution: Standard Cooling Fan
RAID Controller: Onboard RAID Controller
Chassis Selection: Set 101 Mid Tower Black
Chassis Fans: 3x Standard 120mm Case Fans
Chassis Internal Lighting: No Chassis Lights
Power Supply: 700W Thermaltake 80 Plus Power Supply
Keyboard: Gamdias Ares M1A RGB Keyboard & Mouse
Thanks for the help if any im not real knowledgable on this stuff but im trying to learn as much as i can
VirtualLarry
56,587
10,227
This was a pre-built, no? Hopefully it wasn't more than $600-700 USD, preferably more towards the $550 mark.
Edit: Oh, OK. I missed initially that the Seagate was an SSD. That's not a bad budget build.
I probably would have gone for the 9400F and a 1050ti, if they weren't a LOT more, but I recognize that this was slightly budget.
UsandThem
16,068
7,383
4 core / 4 thread build in 2021 for anything other than email/web browsing? That will quickly become a regret for a gaming build (even if 60 FPS are good enough for you).
You could likely fit a 6 core / 12 thread CPU like the i5-10400(f) into your budget for not that much more.
Reactions: VirtualLarry
Oxide-
Thank you for your input no im currently trying to piece something together that would do well with photoshop/editing work and light gaming i was thinkin looking at the ryzen 5 3600 3.60ghz hexa-core instead of the i3 but i dont know how well it will work with the others like i said my budget is between 1-1.2k so im not expecting top tier.
thanks again
Oxide-
i am doing further reseach and im liking the ryzen 5 3600 3.60ghz hexa-core instead is that better?
UsandThem
16,068
7,383
The Ryzen 3600 or the i5-10400 are both great budget gaming/productivity CPUs, and both would be what I'd go with over any 9th gen i3 or i5 CPU.
The Ryzen 3600 is impacted by availability issues/prices, so in that case the nod would go to the i5-10400(f) in the $150ish range.
DreadBelch
101
16
What type of motherboard would you typically pair with an i5-10400 for video editing + FPS gaming? I have an old 6700k, 16GB DDR4 3000 and a Z170 but those Zxxx boards look really expensive now.
UsandThem
16,068
7,383
I'd look into the new new B560 motherboards since they allow memory overclocking, and seem to be reasonably priced:
https://www.anandtech.com/show/1651...ard-overview-30-budget-models-for-rocket-lake
There were not many H470 motherboards available for 10th gen (and they were locked to DDR4 2666 for the i5-10400), and the Z490 motherboards were pricey. I think a lot of the issues of the higher prices were related to availability, so hopefully Intel and their partners can improve availability this time around.
