I recently put together a PC for the first time under supervision only to find myself in a troubleshooting nightmare. I used the following components
Corsair Carbide 500r
SeaSonic Platinum 860w
Intel Core i7 3770k
Cooler Master Hyper 612
Mushkin Enhanced Blackline 16GB 997050
ASUS P8Z77-V Pro
Sapphire Radeon HD 7970 OC 3GB
Crucial M4 256GB SSD
Seagate Barracuda ST1000DM003 1TB
The problem that arose is that the system did not POST, with the dreaded dram LED lit continuously. I tried all possible troubleshooting procedures including pressing the MemOK button with no success in getting the computer to POST. Given that the DRAM LED was lit, and the Mushkin memory not being listed on ASUS' QVL for the motherboard, my helper (who is a computer expert) and I concluded that the memory was incompatible with the motherboard. I RMAd the memory and switched to Corsair Vengeance Low Profile 16 GB (4x4GB) Dual Channel DDR3 Memory (CML16GX3M4A1600C9B). This memory is guaranteed compatible by Corsair on the Asus p8z77-v pro. I installed this memory only to get the same error, DRAM LED continuously lit. After this I attempted to reset the CMOS according to the procedure in the manual, with no success in getting the system to POST. My helper and I concluded that the motherboard is defective and I had it RMA'd with the motherboard sent back to newegg. When my helper and I assembled the system, we made the mistake of mounting the motherboard into the case first before installing the CPU. I then had some trouble inserting the CPU into the socket hearing some scraping against the edges of the CPU socket before I finally managed to get the CPU inserted. Then again we carefully inspected the the CPU and CPU socket for damage and found nothing (no bent pins etc). Another problem that was encountered is that the back exhaust fan would not work. We are not sure, but we think that back fan did initially work. I received the replacement motherboard and reassembled the system, only to encounter the same exact problems (DRAM-RAM LED continuously lit, back exhaust fan not working.) I called ASUS tech support and performed a multitude of troubleshooting tests to no success. The ASUS tech support rep concluded that the problem is incompatible memory. Even if that is the case it does solve the problem with the back exhaust fan. ASUS does not have my memory listed on the Qualified Vendors List of compatible memory. However, Corsair on their website has my memory listed as guaranteed compatible with the ASUS P8Z77-V Pro. I am very frustrated and stumped on what is causing my problems with this computer, which I need to have up and running so I can use the software that I need to be able to use. Any help is greatly appreciated.
Intel Core i7 3770k
ASUS P8Z77-V Pro
