Well not really the first time OC'ing, but first time with a purpose built OC'ing PC.
Here's the setup:
NF7-S rev 2
XP-M 2200 35W
512MB (2x256) Geil mid-lvl PC3200 (left at default 2-3-3-6 timings for now)
I built the system around a SI-97 and a high flow fan. The idea was to use a 90mm tornado (~120 cfm) on the SI-97 ducted straight into the Super Lanboy case as the only intake and then make every other fan in the case vent out and try to equalize the pressure (not quite there yet). I wanted to only blow cooler outside air on the proc not just circulate warmer case air plus these fans move soo much air anyway why not use it as the only intake.
I was able to hit 2.73 (182Mhz, 15x multi, 2.3v) and 2.72 (160Mhz, 17x, 2.3v) running prime95 torture test with all fans at full speed. It ran stable for about 10 min but I was watching the CPU temp (via abit's utility that came w/ the board) and decided to shut it down as it went over 55C and was still slowly climbing. Plus the tornado at even 3500 rpm was just too dang loud and I didn't want to wear ear plugs while playing games.
I went to crapUSA and bought their two highest output fans (Maddog 120mm 100cfm @ 32db, & 90mm 60cfm @ 32db) and played around with the ducting (still a work in progress). I currently have them both running in-line with the 120 just inside the case and the 90 right up against the cooler although I don't know if the 90 is doing much good, need to get an airspeed meter to test with and do some more experimenting. This setup at full speed was MUCH quieter than the tornado at 2/3 speed and still seems to move pretty good air.
Using this setup, I settled for a more modest 2.51 (179mhz, 14x, 1.85v) which has run Prime95 toture test stable for 4 hours so far and the CPU temp seems to max at about 44-46C with fans at full speed.
I have an XP-M 2400 45W chip I'll try out too and need to order some higher flowing 120mm case fans to try to balance the system pressure better (currently using the stock Antec fans which only flow like 25cfm I think.
Some questions for the OC'ing vets out there:
Do I have an exceptional chip here? What do mobile 2200s usually hit? I've heard of a 2500 that hit 2.8 on watercooling, but that's about it.
FSB maxed out at 182Mhz running 2 memory modules in Dual Channel mode (even down at 5x multi) although I could run a single chip at 200-202. I even tried some PC4000 and it wouldn't even run as high as the PC3200. Think this is a limitation of the chip?
The system seemed to not like the 1.875v chip core setting, wouldn't boot at all at that voltage. Also 1.9v was buggy, only got it to boot a couple times. I think I could get a bit more out of it and keep it stable but for some reason I have to go over 1.9v. Does this make any sense? Maybe a board or PSU problem?
Here's the setup:
NF7-S rev 2
XP-M 2200 35W
