System info :
intel c2q q9550
ati 4870
tagan 800w psu
asus p5q pro mobo
8 gb ocz platinum ddr2 pc8500 ram
CPU Z info :
CPU
core speed 3400.0 mhz
multiplier x8.5
Bus speed 400 mhz
Rated fsb 1600 mhz
core voltage 1.144
Memory @ 4-4-4-12
DRAM frequency 400.0 mhz
FSB
RAM 1:1
command rate 2T
BIOS Settings :
CPU voltage 1.18125
CPU pull voltage 1.52
FSB terminal voltage 1.28
DRAM voltage 1.90
NB voltage 1.24
SB voltage 1.10
PCI E sata voltage 1.50
PCI express frequency 100
Speed Spectrum disabled
C1E disabled
Max CPUID disabled
CPU TM function Enabled
Execute Disable bit enable
What are your views on this overclock. I ran prime95 for about 2 hrs and it was stable.
Should I lower the CPU voltage further or is it fine.
Thanks.
intel c2q q9550
ati 4870
tagan 800w psu
asus p5q pro mobo
CPU Z info :
CPU
multiplier x8.5
Bus speed 400 mhz
Rated fsb 1600 mhz
core voltage 1.144
Memory @ 4-4-4-12
FSB
command rate 2T
BIOS Settings :
CPU voltage 1.18125
DRAM voltage 1.90
NB voltage 1.24
SB voltage 1.10
C1E disabled
Max CPUID disabled
Thanks.
