First Time Installation Help (Stupid Questions Here)
BeeBoop
Going to ask some stupid questions so go easy on me.
There are 4 connectors on the back of the RTI A5s that I have. When I hook it up to the AVR, I only pick 2. Is that correct?
Denon 1913 and RTI A5
Correct, the second set of posts are for bi-amping. See the metal straps? They effectively make the two sets of posts into one.
I don't think your receiver can bi-amp, and even if it could, it probably won't result in any noticeable sonic difference.
Thanks. Another stupid question i came across. On the back of the receiver it says left and right but according to which viewpoint?
