First time DIY, what parts do I need?
brian0918
13
For anyone who's put together several PCs on their own:
Besides the core components (listed below), what other smaller parts (cables, screws, anything) do I need to put this thing together? Assume I buy everything through Newegg and they each come with all the pre-packaged stuff you'd expect.
  • X-Discovery Mid-Tower Case
    Seasonic 550W PSU
    Intel Core 2 Quad Q6600 @ 2.4GHz 1066FSB 8MB L2 Cache 64-bit
    Arctic Silver 5 Thermal Compound
    INTEL LGA775 CERTIFIED CPU FAN & HEATSINK (Any suggestions?)
    Intel D975XBX2 I975X mobo
    4GB PC6400 DDR2/800 Corsair XMS2 Xtreme Memory w/ Heat Spreader
    ATI Radeon X1950 Pro PCI-E x16 256MB VIDEO CARD (x1950 is most compatible with my NLE software)
    74GB WD740ADFD 10,000RPM SATA150 16MB Cache
    500GB SATA-II 3.0Gb/s 16MB Cache 7200RPM Hard Drive
    (2x) NEC 7170A 18X DVD+-RW
    Creative Labs X-FI XtremeGamer 24-BIT
    ViewSonic VA1912WB WideScreen 19" Color TFT Active Matrix SXGA LCD Monitor
    OPTI-UPS ES1000C 1000VA/700W
    All the entrails (mouse, keyboard, speakers, etc)
Thanks! :D
ayabe
7,449
Looks pretty good to me.
Your case will come with a bag of screws and standoffs for the mobo.
Mobo should have some SATA cables and IDE/Floppy cables.
Might need some extra SATA cables if you bought your drives OEM, but otherwise you should be all set.
Blintok
429
Just recently put together one myself ... looks good what you listed above.
My MB ( Asus P5B) came with all the cables i needed.
not sure you need the thermal compound, my Intel E6300 and stock cooler came with paste already applied
(unless you want to scrape off the stock compound and apply the arctic)
I (a few days later) replaced the stock with an Arctic 7 freezer pro and even that came with compound already applied.
Blintok
429
well this is what i changed the stock to and it is working great.
http://www.arctic-cooling.com/cpu2.php?idx=79&disc=
was relatively inexpensive (35ish Canadian)
Has the same (stupid annoying :) ) push pin locking system as the stock cooler
It lines up with my rear 20cm case fan so the cooler fan airflow goes right thru the fins and out the back of the case
I have one 20cm fan at bottom front of case blowing in(across HD)
1 20cm fan on rear of case. 1 20cm fan on bottom of powersupply (Silverstone)
and 1 18cm on side of case blowing in. (sits above northbridge\Vidcard\CPU area)
Thot i mite have had a problem when installing it, it is a very tight fit with the northbridge heatsink on the P5B.
but there is about half a pubic hairs space btwn them.
mite want to post this question and or check in the cases&cooling section
