First Time Building Computer !!NEEDS HELP!!
LetapVJ
130
:eek:
I am soon building my first computer but could not decide which Amd Athlon Mobo/CPU combo should I use to build my new computer. I have seen lots of choices in combos. I want the best and really stable computer. The one I have right now is crash too much and I am sick and tired of it. So Please I needs some advice or opinions from someone.
Red Dawn
57,529
<< So Please I needs some advice or opinions from someone. >>
Yeah the best advice I could give you is to figure out what's causing the one you have now rashing? I tmight be the Config and not the Hardware. If that's the case you might end up having similar problems with your new system
Ns1
55,420
1,600
I've gone through about 4 or 5
Asus A7V133, IWill KK266, IWill KA266, MSI K7T, MSI266WhateverTheHellItWas
I found the A7V133 to be the most stable board of the bunch, had the best overall motherboard design, and like it alot
RSI
7,281
Any combo should be ok if you set it up properly.
-RSI <- owns two ECS K7S5A setups
JonnyDuke
369
Well... after you have figured out why your old one is crashing and fix it, go with AMD. AMD can give you the most bang for you buck, heck they can give more bang than Intel even when price isn't a concern!
