First Time Builder Seeking Advice
Akinos
Hi guys. First post, first thread, first time building my own computer. Seeking advice for my build. 🙂 Primarily going to be used for gaming. Company of Heroes, Dark Messiah of Might and Magic. Upcoming Supreme Commander and Spore. Would like to be able to run games on high settings at 1440x900 res (Samsung 940bw). Anyway, here it is:
Intel Core 2 Duo E6600 Conroe 2.4GHz LGA 775 Processor Model BX80557E6600 - Retail
ASUS P5B-E Socket T (LGA 775) Intel P965 Express ATX Intel Motherboard - Retail
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X2048-6400C4 - Retail
eVGA 512-P2-N637-AR GeForce 7950GT 512MB GDDR3 PCI Express x16 KO Superclocked Video Card - Retail
Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Thermaltake W0093RU ATX 12V 2.0 Version 500W Power Supply - Retail
Antec Performance I P180B Black 0.8mm cold rolled steel for durability through the majority of chassis 1.0mm cold rolled steel around the 4 x HDD area ATX Mid Tower Computer Case - Retail
SAMSUNG 18X DVD±R DVD Burner With 12X DVD-RAM Write Black E-IDE/ATAPI Model SH-S182D - OEM
Microsoft Windows XP Pro SP2b 1pk w/Upgrade Coupon for Vista - OEM
I should mention that I do not plan on overclocking, as I have no idea how. Also, I don't know what the Superclocked video card is, but Newegg is sold out of eVGA's regular 7950GT. 🙂
Mainly worried about all of my components being compatible (never done this before). I would also like to avoid putting to much power in any one aspect of the PC, leaving my rig bottlenecking everywhere else...
Thanks!
Yeah you need a Power Supply Unit. dBTelos's selections are nice. Other than that, it is a very nice build and will give you great gaming performance.
Based on Newegg reviews, I was going to go with the THERMALTAKE TR2 500W Power Supply ATX12V V2.0 - Retail:
http://www.newegg.com/product/product.asp?item=N82E16817153028
Or the FSP Group (Fortron Source) AX500-A, 2.0 version, 2 SATA, PCI Express, 500W - Retail:
http://www.newegg.com/Product/Product.asp?Item=N82E16817104934
I've heard that Thermaltake and Fortron are reputable companies, and both of these PSUs have a 5/5 average rating after 60-70 reviews. Are they compatible with the rest of my system?
dBTelos has good info on PSU's. Your selections are decent and certainly compatible.
However, please don't make ANY purchase decissions based on NewEgg reviews! Do a search for reviews on specific components from sites using repeatable scientific testing and real life situations.
Originally posted by: Clevee
This is the PSU that I own, it has lots of power(580w), you can plug in only the cables that you need ( for saving space ), its BEAUTIFUL!!!, blue LED lights in it, 80mm fan, and its only $89.99 +shipping. I've owned it for about 3 months now and had zero problems with it. The quality of this psu is amazing.
http://www.newegg.com/product/product.asp?item=N82E16817128001
That's hot. Now I NEED a PSU with modular cabling! :laugh:
Guess I should go with cheaper RAM, too.
Thanks, guys. 🙂
Alright, after some research, and deciding that I'd like SLI and OCing to be future options for me, here is my updated build:
eVGA 512-P2-N635-AR GeForce 7950GT 512MB GDDR3 PCI Express x16 Video Card - Retail
HIPER HPU-4K580-MS ATX12V 580W Power Supply - Retail
One thing I'm not sure of. In the "Features" for the P5B-E is says:
Notice: Only DDR2-800 memory supporting JEDEC approved 1.8V operation with timings of 5-5-5 or 6-6-6 is supported on Intel Desktop Boards based on Intel 965 Express Chipsets.
What is that about? Will my current RAM selection not work out?
SLI: With this build will I be able to just throw another vid card in?
OC: Once I wrap my head around OCing, will my build be able to do so as is, or will I need extra cooling hardware?
If you want flashy lights, put in a couple cold cathods. If you want modular cabling, then the HX520W from Corsair. It will last much longer then any Hiper and has better quality. If you don't plan on SLi then the Sunbeam Nuuo could power one of those cards. It's the 450W version. NeoHE is another option (430W). All are modular.
