This is such a simple question but I've never built a computer so I have a good excuse
So I'm using the Thermaltake V41 case and ASRock Fatal1ty Z97 Professional MB for my first build and I had a question about the type and length of the SATA cables I should use.
I will be installing a SSD, HDD and a DVD burner.
The SSD and HDD will be installed in the hidden compartment of the MB, were typically you hide your wires. This will allow me to remove the 2 cages to increase airflow etc.
The DVD burner will be installed on the very top cage.
My first question is given my setup what type of SATA cable would be my best option for the cleanest wire management look
1. straight to straight
2. straight to 90 degree
3. 90 degree to 90 degree
My second question is what is the shortest length cable I can go with that would work for all 3 applications. The most common one seems to be 18" however as I mentioned before I want a clean look and hence the shortest lenght that would work for all 3 since I'll be buying like a multi-pack. They come in 10, 12, 14, 18, 20" etc.
As I said before this is my first build and can't imagine the wire lay out hence the simple stupid question
Thanks!
Thanks!
