- Mar 9, 2009
- 441
- 1
- 81
This will be used for gaming (nothing to serious), and internet usage. I'm upgrading from a Dell system consisting of:
Intel P4 3.2G
Nvidia Geforce 6800
3 Gig DDR2 533 mhz
Windows XP
This system strugles with NWN2 at moderate settings, but internet usage is fine. I don't have any biases, just like bang-for-buck components but realise sometimes you have to spend more for quality. Here's the system I'm considering for my first build:
Intel Core 2 Duo E8500 Wolfdale 3.16GHz
ASUS P5A2-8SB4W 80mm Sleeve CPU Cooler
Intel BOXDP45SG LGA 775 Intel P45 ATX Intel Motherboard
mushkin 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333
HIS Hightech H487FN1GP Radeon HD 4870 1GB 256-bit GDDR5
RAIDMAX SMILODON Extreme Black ATX-612WEBP 1.0mm SECC Steel ATX Mid Tower
HIPER Type M II HPU-5M730 730W Continuous @ 40°C
Seagate Barracuda 7200.12 ST3500418AS 500GB 7200 RPM
Scythe DFS123812-2000 120mm Case Fan x2
LG 22X DVD±R DVD Burner with LightScribe Black SATA Model GH22LS30
Cost is about $1030 before tax and shipping from Newegg. I have the flexability of adding another GPU for crossfire with this setup, which I like for a bit of longer term usage. I'm not sure how much longer the LGA 775 socket will be viable if I want to upgrade to a quad core in the future though (will core2 quads continue to advance)?
Intel P4 3.2G
Nvidia Geforce 6800
3 Gig DDR2 533 mhz
Windows XP
