First time build!Please check build.
Timany
Will this be enough for surfing the web and watching videos online?
This is the first time I'm building a computer.
Do I really need to buy a thermal paste? If so, what kind should I buy?
If you have any other suggestions or anything else I need to buy like thermal paste or static strap, PLEASE LET ME KNOW!!
Thank you so much.
MY BUILD: hmm::
PSU: Corsair Builder Series CX 430 Watt ATX/EPS 80 PLUS (CX430)
CASE: NZXT Technologies Source 210 Computer Case (Black)
RAM: Crucial 4GB Kit (2GBx2) DDR3 1333 MT/s (PC3-10600) CL9 Unbuffered UDIMM
240-Pin Modules CT2KIT25664BA1339
CPU: AMD A4-5300 APU 3.4Ghz Processor AD5300OKHJBOX
MOBO: MSI AMD A55 MicroATX DDR3 1600 370 Motherboards FM2-A55M-E33
STORAGE: Western Digital Caviar Blue 500 GB SATA III 7200 RPM 16 MB Cache Bulk/OEM
Yes, your build is enough to surf the web and watch HD video. Depending on your browsing habits, I would suggest 8 GBs of RAM if you're the type who keeps a lot of tabs open. Otherwise, 4 GBs would indeed suffice.
No thermal paste is needed in your situation. Also, I agree with Torn Mind on the RAM. A 4 GB DIMM is only 35 bucks in newegg.com
Also, Seagate Barracuda 1 TB HDD is really cheap. It has twice the space and many times more cache, while only being a bit more expensive.
