First time 1200 dollar computer build, any advice/ tweaks
chucker46032
23
Alright! Great, i noticed it was a micro atx what's the difference between mic4o atx and atx i$ there is a huge difference i could go with atx, it seems like the micro atx may jave some problems fitting a larger.video card
mnewsham
14,539
428
It is all standardized and it is an SLI certified board so no it will all fit. It is just a smaller form factor that will fit in smaller cases Recently there has been little difference but size, it used to be mATX would only have 1 PCI slot and 2 RAM slots, now they fit everything a full ATX board can fit though.
chucker46032
23
Great!! I went with the board suggested, as well as a intel I5 2500k and am extremely glad that I went with this combo. However, im currently installing the mother board and there are a few questions I have about the screws that go into the standoff ( I have all the standoffs lined up with none un-used behind the board. I have 2-3 different types of phillips screws that each screw into the standoffs. Should I use the hex head, or circular? Also there are a few washers included, should i place these between the mobo and the screw that goes into the standoffs?
mfenn
22,400
www.mfenn.com
In All honesty, it doesn't matter too much, as long as the threads match. Technically, the hex head ones are for the PSU and 5 1/4" drives and the circular ones are for the mobo. You don't need to use any washers.
chucker46032
23
Alright, since i've saved so much money from advice i've gotten through this forum I think i'm going to up my video card a notch..
-MSI HD6950 2GB http://www.newegg.com/Product/Produc...82E16814127562
XFX HD6950 1GB XXX - http://www.newegg.com/Product/Product.aspx?Item=N82E16814150530&Tpk=HD-695X-CNFC
[FONT=Verdana,Arial,Helvetica]-[/FONT]Diamond HD6950 2GB http://www.newegg.com/Product/Produc...&Tpk=6950PE52G
EVGA GTX570HD SC 1.2GB - http://www.newegg.com/Product/Product.aspx?Item=N82E16814130620&Tpk=012-P3-1573-KR ( on sale for 290$ at my local electronic store
EVGA GTX570 1.2GB 012-P3-1570-AR http://www.newegg.com/Product/Produc...012-P3-1570-AR on sale for 300
Alright, well those are some quick choices that I have made. Didn't jump out and make any purchases out of fear of bottle necking this cPU (intel core i5 2500K) I also have 8 gb's of ddr3 ram at 1600 mhz, and the plan is a 600 watt power supply but if that needs adjustment that's alright ( haven't bought the PSU yet). Well, thanks for the help again! The build is going great ( knock on wood lol ) and i'm glad i've gone with everyones suggestions the PC looks great ( specs are even better glad I went with the z68 after I did some more research ) Let me know what you guys think of the video cards!
chucker46032
23
Unfortunately they don't have that card in stock :( The reason im avoiding newegg so much is because this is a build for my younger brother for his birthday which is the 5th of this month. Card looks great though, and I would love to get a free game with it but unfortunately there isn't enough time to wait for it to be shipped :( Gonna go ahead and include a link to Frys electronics (local store) ( from what i've seen they have prices that rival newegg )if it's not too much trouble it'd be much appreaciated if you could take a look around the GPU section and see if theres anything that looks good..if the 600W PSU needs upgrade let me know. Thanks once again! Hope it's not too much trouble
http://www.frys.com/category/Outpost...terAreaString=
chucker46032
23
Also preferably i'd like to go with NVIDIA for the 3d vision, can ATI support 3d vision glasses + monitor?
mfenn
22,400
www.mfenn.com
AMD's 3D support is much weaker than Nvidia's right now. 3D Vision is one of those love or hate it things though. I would be very cautious about buying it for someone unless I knew that they had tried it and liked it.
3D notwithstanding, the card that mnewsham linked would be my choice and it shows as in stock for me now.
B-Wing
If you are wanting/needing to buy from your local Fry's, they are suppost to price match online retalers like NewEgg now, but YMMV. Not sure if your local Fry's has the card that mnewsham linked but it may be worth checking.
chucker46032
23
Thanks for all the advice everyone! My first build went great! The pc is amazing! Don't think i could have gone with a better motherboard, started up on the first try. For the videocard i went with the msi 6950 twin frozr II 2gb OC edition. It's a great card, I'm running crysis 2 at a stable 60 fps with dips down to 45 fps with absolutely no stuttering. ( without the dx11 patch and the hd textures ) haven't had a chance to rate the fps with dx11 and hd textures but ill post the stats when i do. Thanks again! ( if anyone thinks of a better video card i have a 15 day period to test it out ) still have some money to use if an upgrade of the videocard is suggested I could upgrade .
