itsmydamnation
Its going to be interesting to see single thread branchy int code performance ( like spec gcc)
AMD is so proud of their prediction and prefetch algorithms that they gave them some goofy marketing names that likely puts them out of touch with reality. (how they really work)Its going to be interesting to see single thread branchy int code performance ( like spec gcc)
Great comment! Never seen that perspective before.Just don't be surprised when the hype train meets reality and it turns out AMD has carefully cherry picked these benchmarks to build up the hype.
Turns out the future wasn't fusion after all.Also on the i5 front it has 1/2 it's die size given to a gpu your not using so who knows where amd will price the 4 and 6 core.
It's funny amd are showing benchmarks where there design can be exposed to its greatest weaknesses which is its it's 1/2 load store width of haswell yet it's keeping up. They haven't even benchmarked the area where they should see the biggest improvement vs excavator branchy integer code.
8 core at Intel 6 core price
6 core at quad i7 price
4 core with ht @ i5 price
That would put the cat amongst the pigeons and make amd plenty of money.
I actually tested this at the time the first 6900K vs. Zen demo came out. Dual channel was MARGINALLY faster 🙂
What cause of this ? wrong file?That's not the discrepancy being pointed out.
The 6900K in the AMD demo is scoring 35.44 seconds at 3.4GHz.
So far, one 6900K clocked at 4.2GHz using the file is scoring 42 seconds. Same CPU, same OS, AMD specified Blender version, AMD test...25% higher clock speed, 15% worse performance.
This also corresponds exactly to what I'm seeing on my 5820K and 6800K. I've been using Blender for ten years, it scales almost perfectly linearly with core clocks and number of cores, but not it, and not anything, scales much better than linearly.
A 6900K has the same architecture as my 6800K but has 33% more cores. With a 33% OC on my 6800K, I should score nearly the same as a stock 6900K. With a 33% OC, my 6800K scores 51-52 seconds. Same goes for my 5820K, same clock, almost the same score because almost the same architecture.
Anyone with a stock 6900K who uses the file AMD has for download will get ~52 seconds. Not the ~36 seconds AMD's demo 6900K is showing.
I did my best to enhance the image
AMD performing better than SKL I'll have to see. From what I remember, the architecture isn't all that exotic.
OoO window: HSW level.
Loads: HSW/SKL.
Stores: HSW.
Scheduler entries: SKL.
Register: SKL.
So, does anyone expect it can break 4 ghz?
4 narrower SIMD units is also interesting.
The stack engine generating memory addresses (is there any stack cache in the end?)
And the l/s system looks like a pretty big departure ( but who knows what Intel does)
They are especting 3.4GHz base and 3.425 single core turbo, just to stay under the beloved intel chips...They promise a 3.4G+ base clock & people are still worried if it will hit 4G.
Sigh....
Somethings never change..
Sent from my Nexus 5X using Tapatalk
The big difference is the wider retire, wider fetch and higher bandwidth of uops from uop cache. I suspect that they mostly help in highly threaded loads.
Their branch predictors are also based on entirely different designs than the Intel ones. Whether they are better is still an open question.
Two options:
A. AMD used a build with AVX256, which apparently lines up with the scores
B. AMD used a lower sample rate (from 200 to 100), which again lines up with the scores
also whats your memory clocked at for the 6700k?
looks like 2.77 to me good catch.. wonder if there is much difference. but could that be from the other demo they gave to press?do those screenshots say V 2.77 ? I can't quite read it.. Cat: Enhance!
Thought someone posted some footnotes saying 2.78a
