First SSD, write numbers seem low
SithSolo1
Just put the system together a few hours ago, everything is new but the dvdrw and video card.
x2 555be (stock)
MSI 785G-P45
4gb G.Skill Ripjaw
Patriot Inferno 60GB
WD 640GB BE
8800 gts 320
AS SSD uses non compressible data for the benchmark, therefore SandForce can't gain an advantage from its DuraWrite technology.
The claimed speeds for this drive are from ATTO. Before you RMA drive, check the speeds with the ATTO benchmark.
You can get the new crystal 3.0 as well and smply change the test method to 0Fill which will then imitate the manufacturers listed specs...
