First Self Build, computer won't turn on, please help
mdrollas
Was so excited to get my first own build yesterday. However, after everything installed, but computer wouldnt turn on. The only thing on was the green led on the mother board. Not even the PS fan.
What can be some of the possible problem?
thanks!!
Are you sure you hooked up the relay wires from the case to the motherboard correctly, for example the power switch button?? I figured I would start simple.
I think that might be the problem, because I don't know which ways the wires go in.
Case: Antec SLK3700, Mobo: Asus A8N5X
thanks!
