Sorry this may be a bit long , but I have described a sequence of events which is
probably essential in the diagnosis.
My system is Athlon 1000 T?Bird; 512 SDRAM 133; MSI MS6340 Ver 1 mobo;
GTS2 Vid card; Santa Cruz sound card; ATX case with Enermax 350 w PSU
I have changed my PSU from a 235 w to this new one. The reason Ii did it was that ,
after a sudden close down when playing a flight sim, I switched on again and nothing
happened POST wise, all I got was nothing on the monitor. But the CPU fan worked
and so did the switch lights, but that was all. No Bleeps. I suspected the Power_good
signal wasn?t getting thru( having read Scott mueller?s book on PC?s and so ordered a
replacement PSU, as I thought mine was going on the blink.
On one occasion, the PC did boot up and I thought all was Ok , but some two days
later it suddenly went off, again, in the middle of a flight sim.
The new PSU I got was the Enermax 365P - VD. I wernt to fit it today and still a
problem as below.
I have a MS 6340 Ver 1 mobo. It is fitted with a AMD Thunderbird 1000 processor.
I have fitted the plugs of the PSU the same as when they came out of the system and
they are;
1. The twenty pin (Pl) plug which goes into the motherboard.
No other plug was taken out of the motherboard when i disconnected the PSU.
2. The peripheral connectors to Hard drive; CDRom; CD Writer; (4 pin )
3. The floppy connector.(4 pin )
There are two other sorts of plug which I haven?t connected to anything. In the PSU
manual they are described as
a) Aux power connector (Pentium4 )
b) +12v Power connector (Pentium 4 )
In view of the (Pentium 4 ) after their description , I presume they are only applicable
if i had a pentium 4 processor and therefore a pentium 4 motherboard.
I cannot see what else I need to plug in. So, I switched on .
The switch light comes on.
The CPU fan goes round ,
There are three bleeps; then three more bleeps; then three more bleeps and so it
goes on. Can someone confirm that this is a Post Audio Error code. If so, what is
indicated?
My BIOS , according to the round disc on the motherboard says 686
AMIBIOS
c1999
AK87
2796
I hit the switch to turn off , but nothing happens, The switch stays on, the bleeps keep
going.
Now, I remembered that Scott mueller?s book said that there were audio error bleep
codes on a CD with his book, and I found the CD. I looked and behold, three bleeps
for Amibios is a memory problem.So I took out the memory dimms ( two ) and re
located them and switched on and Hurrah - It all WORKED!! Brilliant- Problem
solved and all right, maybe I had changed the PSU unnecessarily , but it now ran very
quiet and I knew I had a quality powerful PSU.
I had several days of good working order from the ?puter, including some intentional
shutdowns at night and restarts OK.
Then yesterday, 13 (sic!) January it stopped again in the middle of a flight sim.
Earlier that day, I had run Norton Utilities and decided to have a hardware diagnostics
check.
It told me there was a fault somewhere on the memory!
Then later, the system stopped as described.
So, I figured that the memory fault had developed and caused the crash ( I think now
this may not be right but see later ) and as my 512 SDRAM memory was in two 256
sticks, I decided to put in one stick at a time and when it ran then I was using the good
stick, Right?----------Wrong!
It wouldn?t boot and although the switch comes on , and the fan on CPU and Video
card goes round, there is no sign of a boot up.
Ominously, there is no bleep as there was last time which worried me as to whether
this was a memory problem like last time. After many attempts there is no luck and
there has never been any bleep-
It?s as if there is a missing connection.
I have done the following;
I have?rung the changes? on the memory- both sticks one at a time in both DIMM
slots; and together in both DIMM slots. No change No bleeps
I have changed the monitor cable . The new one was working on my second
computer OK and the original now works OK on the second computer. No
change- No bleeps
I have swapped video cards ( both AGP ) No change - No bleeps.
I have unplugged and re-located the Power supply 20 pin plug to the mobo.
I have unplugged and relocated the JFP1 plug on the mobo
I have done the same with the only other plug to mobo, which I think is called a
J8 plug.
I have unplugged and re-located the hard drive ribbon plug to the IDE1 socket on
the mobo.
I have unplugged and re-located the power plug to the hard drive..
All resulted in no change and no bleeps.
As I say, the fans on the CPU HS and the video card are working.
There is no smell of burning from the CPU area.
Conclusions?? - In view of the lack of bleeps I think the memory is not the problem?
But could both sticks have ?blown? - I would have thought that at least one of the
sticks should be Ok and there would be a bleep if memory problem?
It is as if there is a dry joint on the mobo or an intermittent connection somewhere has
maybe become permanent.
Or, for some reason, there is no Power_Good Signal getting to the mobo. Unlikely
though in view of the one week old Enermax 350 w PSU?
So, I?m going to attempt to fully strip the ?puter in a day or so- ( I?ve never done that
before ! Oh My Gawd! ) and then subject to advice from the good old internet, I
might have to put in a new mobo and CPU!
What would you check next to cure this, and how??
What really is niggling is that it may be hardly anything wrong, just a connection!!!
Advice would be greatly appreciated - but be gentle on this near 60 yr old.
Thanks in advance.
problem as below.
they are;
indicated?
AMIBIOS
c1999
AK87
2796
going.
check.
change- No bleeps
J8 plug.
the mobo.
Thanks in advance.
