Hey all, I'm looking to build my first PC and was wondering if you'd give me some feedback on what I have selected. I've been a Mac user almost exclusively, but at this point am fairly platform agnostic. I want to better understand PCs and build something that will be used as a gaming platform and a home media center. The display will be a 1080p HDTV, but I'd like to allow for higher resolutions than that should I choose to run a 27" monitor from it.
I don't plan on doing any overclocking as my expectations are fairly low--the best performing rig I've used is an iMac with 3.4 GHz i7 with the AMD Radeon 6970M, but as I don't know much about it I'd like to leave that option open.
Noise concerns aren't too big a worry, as it will be in a large room at least 8 feet away.
I'd like to keep it around $1,000. My entire budget is near $2,000 including TV (I'm planning on the Panasonic TC-P50S60 which is $650).
Anyway, here's the build:
Fractal Design Arc Midi R2
Intel i5 3570k 3.4 GHz
Gigabyte GA-Z87X D3H
EVGA P4-2662 GTX 660
SeaSonic M12II 650AM (I ran the build through PC Part Picker and the estimate was 350w, so depending on feeback I could go down on this)
Crucial Ballistix Sport 2x4 GB
SanDisk Ultra 128GB SSD
WD 2TB Caviar Black
Cooler Master Hyper 212 Plus
Pioneer Electronics USA 15x SATA Internal BD/DVD/CD
~Total: $1,124.91
+ $60 for DVD/BD, eventually I'll probably add in a 4TB WD Red for movie rips.
I know very little about motherboards, but both Gigabyte and ASUS have been recommended to me. I have heard about some QC issues with ASUS, but I have their N66U router and it is incredible. I'm wondering what the best choice would be for that.
Also as mentioned, this might be overkill for the PSU, so I'd love some feedback on that.
Would this graphics card be able to run most games at 1080p on high @ 60FPS? I'm thinking Skyrim, Borderlands 2, Diablo 3, Witcher 2.
I have a copy of Win 7, so that's not a concern, but I will need to add in a wireless keyboard and mouse. any recommendations?
Would love to know your opinions, and THANK YOU!
WD 2TB Caviar Black
~Total: $1,124.91
