I'm having a surprisingly hard time googling an answer to this. Someone help? 🙂
What was the first consumer PC platform to use dual channel memory? Was it used at the same time as the first DDR SDRAM?
Thanks!
The Intel 850 chipset would be the first one to support dual channel memory and it was introduced in Nov 2000.
Does memory interleaving "count" as dual channel? Because that was around in the early '90s.
That's what I was thinking too. I remember having RAM sticks be in pairs only in the 486/Cyrix days.
No wonder rambus was a pile of garbage from start to end.RDRAM dual-channel setups didn't work the same as DDR dual-channel though. If you plugged in extra RIMMs, it would increase system latency. So there was little benefit to adding extra RIMMs.
The RDRAM killed the PIII with it's latency
and the 815 SDRAM chipsets were limited to 512MB of SDRAM when they were finally released, initially only available on the mobile platforms.
I paid $78 for 512MB for my PIII laptop shortly after I got it. The laptop would have remained useful for a lot longer as it was pretty much the same performance as the Pentium M, but my Pentium M laptop could handle 4GB of RAM, my PIII maxed out at 512.
You're dead on about the PIII bus though, the PIII was designed around mid range bandwidth and low latency. The bus was 64bit 133MHz if memory serves. The memory was 64bit 133MHz. RDRAM ran at 600 or 800MHz, the latency wasn't that great and it had to translate from 133MHz to 800MHz, there's a buffer, sync issues, etc..
They seriously attached a memory standard that would cripple the PIII to the last generation of the PIII. You either had to go with Via or Sis to have memory capacity and SDRAM. Pretty sure Via had a short lived DDR chipset for the PIII. Sis just had poor performance, but you could have more RAM. That whole situation helped AMD a great deal.
I upgraded to another ASUS board with the E7205 (RDRAM was stupid expensive at the time) dual channel DDR chipset
In between then and there, I tried out an Athlon XP 1600+ system with an nVidia nForce chipset, but it was unstable as all hell from what I recall. So, the performance of AMD was enticing at the time, and I did try their platform, but ultimately went back to Intel for stability.
I have fond memories of that one. It had the performance of the 850E, but at much lower cost.
The P4 really came into it's own with the 875/865 chipsets, which were more-or-less consumer versions of the E7205.
Yeah, the usual suspect was the HDD controller. Drivers were unstable, but you could use the standard MS driver for better results. Don't get me started on VIA or SiS chipsets.
Edit; Oh, ninja'ed by 0ldman79...
lol
You got beaten to the punch by an old guy!
