1. im using twisty ties to bundle up severl modular leads on my psu and my sata cable for my hdd. will the twisty ties cause any electrical/static problems?
2. i only have 1 sata hdd and 1 dvd burner at the moment. i have my other dvd-rom drive and floppy drive on my old comp which is at my college atm. however, i have no more 4 pin connectors on my psu, is there a way i can split one 4 pin power connector into two?
3. how can i transfer files from a PATA drive to a SATA drive? i dont even know where to start, never had a system with RAID or anything.
4. what is considered a good idle cpu temperature. mine is 37-8 degrees Celcius idle. But when i max out the cpu fan i get 28 degrees celcius. is that bad for my fan?
