First PC Build - Did I get it right?
Not long ago, I decided to build my first PC. I feel like I've gotten all of the parts picked out thanks to the internet and some very friendly strangers on these forums but before I order anything, I'd like to hear some opinions on my parts list:
CPU (Intel Core i5-4690K): http://www.newegg.com/Product/Product.aspx?Item=N82E16819117372&cm_re=i5-4690k-_-19-117-372-_-Product
Motherboard (MSI Z97 PC Mate): http://www.newegg.com/Product/Product.aspx?Item=N82E16813130779
RAM (Crucial Ballistix Sport 4GBx2): http://www.newegg.com/Product/Product.aspx?Item=N82E16820148544&cm_re=crucial_ballistix_sport_8gb-_-20-148-544-_-Product
GPU (SAPPHIRE Radeon R9 290 4GB): http://www.newegg.com/Product/Product.aspx?Item=N82E16814202143
HDD (WD Blue 1TB): http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339&cm_re=wd_blue-_-22-236-339-_-Product
Optical Drive (ASUS 24x DVD Burner): http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204&cm_re=asus_24x_dvd_burner-_-27-135-204-_-Product
PSU (Corsair CX600): http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
Case (Corsair Carbide Series 300R): http://www.newegg.com/Product/Product.aspx?Item=N82E16811139011
Monitor (Acer S240HL 24"): http://www.newegg.com/Product/Product.aspx?Item=N82E16824009739
I'm intending on using the PC for Skype, screen recording, several internet tabs, and HD YouTube videos while playing games such as Minecraft, DayZ Standalone from Steam, and the upcoming Metal Gear Solid V: The Phantom Pain on max (or close to it) settings at 60+ fps. I know this rig wouldn't allow MGS5 to hit 60+ frames at max settings but it should get close.
I'm right around my budget but any and all feedback, suggestions, etc are welcomed with great appreciation. Thanks in advance and have a great day. 🙂
Mostly looks pretty decent. The main thing I see missing is an SSD.
But could you please answer [thread=80121]these questions[/thread] for us? I'd say there's a good chance we can do better somewhere in there.
Sure!
1. (use) Skype, screen recording, several internet tabs, and HD YouTube videos while playing games such as Minecraft, DayZ Standalone from Steam, and the upcoming Metal Gear Solid V: The Phantom Pain on max (or close to it) settings at 60+ fps
2. (budget) $1,000. I can go up to $1,100 if necessary but $1,000 is ideal.
3. (where am I getting the parts) Directly from amazon.com and newegg.com. No preference over one.
4. -irrelevant-
5. (brand) Intel CPU other than that, no preference just performance
6. (current parts?) None - building completely from scratch.
7. (overclocking?) Nope. Default speeds
8. (resolution) 1920x1080
9. (when are you building?) Sometime soon. Before Windows 10 is released (7-29-2015)
10. (+any software) No.
http://wccftech.com/intel-launches-...th-august-skylakes-platform-roadmap-detailed/
Basically Intel gave up on the the 5000 series generation for desktops and is skipping straight to the 6000 series. By waiting you will gain 2 generations of improvements to the motherboard technology, faster onboard graphics and more CPU performance as well. Not to mention DDR 4.
You would probably getting a motherboard using the z170 column below if you waited:
vs
Z97
You can get a 250 GB Crucial SSD for $90 right now. I would not build a new computer without one. Waiting a short while for the next Intel CPU isn't a terrible idea, except that it may require DDR 4, which will cost a good bit more.
[post=37537226]Here's a link[/post]. Thing is you're not overclocking, so you don't need a "K" processor. And they're not releasing the non-K processors and non-Z mobos until September. Tough call.
Is there any benefits from getting a 256GB SSD as apposed to a 64GB or 128GB aside from more storage?
Here's what I came up with if you buy now:
PCPartPicker part list / Price breakdown by merchant
CPU: *Intel Core i5-4690 3.5GHz Quad-Core Processor ($224.99 @ Amazon)
Motherboard: *ASRock H97M Anniversary Micro ATX LGA1150 Motherboard ($71.98 @ Newegg)
Memory: *A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory ($42.99 @ Newegg)
Storage: *Crucial BX100 250GB 2.5" Solid State Drive ($84.99 @ Amazon)
Storage: *Hitachi Deskstar 1TB 3.5" 7200RPM Internal Hard Drive ($40.50 @ Amazon)
Video Card: *Sapphire Radeon R9 290 4GB Tri-X OC Video Card ($263.98 @ Newegg)
Case: Corsair Carbide Series 300R Windowed ATX Mid Tower Case ($97.98 @ Newegg)
Power Supply: *Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply ($44.99 @ Newegg)
Optical Drive: *LG GH24NSC0 DVD/CD Writer ($12.99 @ Newegg)
Monitor: *Acer S240HL bd 60Hz 23.6" Monitor ($109.99 @ Newegg)
Total: $995.38
Prices include shipping, taxes, and discounts when available
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2015-07-07 18:04 EDT-0400
If you decide to wait for Skylake, we'll discuss that later.
The larger SSDs are a little faster.
Most SSDs get slower as they go smaller.
Installing all aps on the SSD will give you good, consistent performance.
Having all your apps and frequent files on the SSD will make the computer a more efficient machine to work with.
If you're going with Skylake (the new generation of CPUs) you'll need DDR4. If you decide to stick with Haswell, I'd recommend going with the low voltage Crucial Ballistix. It's the same price and performance, but has significantly lower voltage and thus will use a little less power and dump less heat in your case. It's not a huge difference, but I can't see any reason not to.
If you want to spend a little more, I would also recommend an IPS-panel monitor, as opposed to a TN. The colors and viewing angles are better. A lot of people still like TNs just fine though.
Overall, pretty solid though.
Would anything aside from the CPU and Motherboard change out of that list if I were to wait?
RAM, too. Skylake does not use DDR3. The rest should be the same.
EDIT: Haswell is already more than enough for most people, but it seems a shame to me not to wait if building from scratch, since Skylake is so close.
Intel has historically released new CPUs at the same pricepoints as the old ones. They're faster, use less power, and cost the same. The old CPUs won't drop in price, but rather will be phased out.
They might be a little more, but not significantly. I haven't watched motherboard prices too closely. The bigger issue is DDR4 - it's a new(ish) tech and has a premium over DDR3, because not much uses it yet. I'd still go Skylake, personally, but it's more of a question for those who already have a few sticks of DDR3 laying around.
So would you recommend http://www.newegg.com/Product/Product.aspx?Item=N82E16824009483&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID= over http://www.newegg.com/Product/Product.aspx?Item=N82E16824009739 for a gaming monitor?
Based on the listed specs alone, I'd pick the IPS, yeah. "5ms" is almost always nonsense, and it's likely the TN panel has slightly lower input lag and response time, but everything else an IPS screen brings is easily worth it to my eyes.
