Hey all,
I've been meaning to put together a computer for the last two years and I'm finally getting around to it. In the mean time I've been using a couple of laptops and netbooks... unfortunately the overprevalence of crappy flash on the internet overwhelms my laptops and I can't even play HD video, so it's time for an upgrade which will also let me catch up with all the cool FPS's I've missed out on.
I have a long-term fiscal outlook (I'm cheap) and I think buying a $400 graphics card is dumb when I can get the same performance for $100 in two years. Therefore, I'm looking at buying a decent motherboard (I want SATA3/USB3 and PCIe 3.0 if I can get, a fairly slow CPU since it affects gaming much less than GPU (Celeron 530 or the next-in-line Pentium to get hyperthreading, see below), and a budget to moderate GPU.
The standard Q&A is below, but I have a few questions I've been trying to resolve after researching all this morning.
A. What am I missing out on my doing a sandy bridge celeron rather than a pentium/i3/i5, other than raw performance in video editing/encoding/etc? So far I know I miss out on hyperthreading. How big of a deal is this for gaming? What about for virtualization (I do play with VM's, and will probably virtualize linux, but I won't necessarily need a hefty distro)? Keep in mind I'm used to running a centrino from 2005, so a sandy bridge celeron is going to be a huge improvement.
B. What is my best bet for a GPU to get started on all the games I missed out on the last 5 years? Keep in mind I don't need "future proofing" because I intend to buy a new one in 2-3 years.
C. LG 1155 looks like my platform, but I haven't decided on chipset/mobo yet. Any solid price/features winners here? What features should I make sure I get other than the ones I mentioned?
D. I think SLI would destroy my heat/noise economy in the cases I'm looking at, but how viable an option is getting a mobo with dual 16x slots and then grabbing another GPU for SLI when prices come down?
Standard questions follow, thanks for your time!
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Internet and gaming, but it doesn't have to be cutting edge for gaming. It has to be quiet, so I'm planning on buying an Antec Solo II or a Fractal Dynamics R3.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread.
I am willing to spend up to $1000 on the box, excluding monitor. I think I can get away with less than $1000 but I'm open-minded.
3. What country YOU will be buying YOUR parts from.
USA, Washington state.
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
Definitely no bias here. I understand Intel chips are faster and cooler than AMD, so I am leaning that direction.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
NA
7. IF YOU plan on overclocking or run the system at default speeds.
Might overclock down the road, not a primary consideration.
8. What resolution will you be using?
I have a 22-ish" LCD, so 1920x1080 (native) would be ideal, but I'm not above using 1600x900 if I need to.
9. WHEN do you plan to build it?
I want to order everything within the week, then upgrade again in 2-3 years.
NA
