I am building my first mid range gaming rig and need expert advice for it. I have gone though the sticky post and started some research.
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Gaming and photoediting on 24" 1080p monitor and Benq w1070 projector.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$1000-$1200
3. What country YOU will be buying YOUR parts from.
Canada
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
We can't be expected to scour the internet on your behalf, chasing down deals in your specific country... Again, help us, help YOU.
I am mostly buying the items from below links:-
http://www.tigerdirect.ca/
http://www.newegg.ca/
http://www.canadacomputers.com/
http://www.ncix.com/
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
nvidia, intel, WD
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
mouse, headphones
7. IF YOU plan on overclocking or run the system at default speeds.
Planning to overclock
8. What resolution, not monitor size, will you be using?
1920x1080
9. WHEN do you plan to build it?
Note that it is usually not cost or time effective to choose your build more than a month before you actually plan to be using it.
Within a week
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
OS - win 7 premium or pro
I have started with below components:-
Processor (CPU) - i5 4670K @ $239 on tigerdirect.ca. Planning to order.
Motherboard
Video/Graphics Card (GPU) - Currently looking for GTX 770 ( also want to know which brand to go for).
Power Supply (PSU)
Case Fan(s)
Case
Memory (RAM) - 8GB
Hard Drive (HDD) - 1 TB WD $65 ordered
SDD - 120 GB - Crucial $82.99 ordered
monitor - 24" 1080p (gaming/photo editing)
Keyboard - basic
OS - win 7 pro - $75 ordered
Please let me know if anyone find a deal on the items.
Thanks
$1000-$1200
Canada
nvidia, intel, WD
mouse, headphones
1920x1080
Within a week
Motherboard
Power Supply (PSU)
Case Fan(s)
Case
Memory (RAM) - 8GB
Keyboard - basic
Thanks
