Mrvile
Anyway I was tired of waiting for my vid card and case to arrive so I got started on some simple things with my computer today...
I took off the stock heat sink that Monarch gave me for free, made a mess with their thermal paste, scrubbed my Winchester 3500+ with some rubbing alcohol, and proceeded to put the XP-90 on. First weird thing I noticed was that the mounting plate screws that came with the original motherboard were too long for the XP-90's mounting plate (when screwed all the way in they stuck about a cm out from the back of the motherboard), so I had to use nuts to compensate for the length. I put the Arctic Silver 5 on (hopefully the right amount, it looked fine) then smacked the heat sink on. Snapped it down to the mounting plate, put the fan clips on, and snapped my 92mm Panaflo into place. Looks great, everything fit perfectly (except the little thing with the mounting plate but no big deal) and the XP-90 is surprisingly light. My dad walked in, took one look and was like, "Is that the heat sink?? Jesus that must weigh a thousand pounds" I was at CompUSA the other day and looked at some of Thermaltake's copper HSFs and the XP-90 is much lighter than a lot of TT's 80mm models. Awesome.
But a few questions. I plugged my memory sticks on the DIMMs that were right under the heat sink (so the fan can blow accross them) but I noticed that the purple and green ones were labeled differently. Does it matter which two I use?
Fans spin counterclockwise right?
Can I leave the stickers (bar codes, labels, Made in China) on the motherboard? I don't feel like taking all of them off.
Thanks!
Thanks!
