Unrelated to power, the case cables (reset, power switch, LED etc.) should be a single plug and cable (like USB/audio) and not the single plugs they currently use (where you need to use a good light and the manual to fiddle the plugs on).
That all would dramatically reduce installation labor, and de-clutter. hopefully it also would reduce cost somewhat. We wouldn't need modular PSUs (only need graphics plug, and single mobo plug), need much less cable management, have smaller cables.
Yeah, the HDD light was used when an HDD just took so long that the user needed a visual feedback if it does something at all. Nowadays with SSD, this is obsolete. Same with reset button. All PCs now re-start by pushing the power button. All we really need is the power and LED. Could be one 4-pin connector.Yeah, it kind of boggles my mind that the case cables have basically not changed in over 25 years. It really does not make sense.
My fear with these 12V power supplies is, they require new mobo and PSU, but don't really resolve all the old problems at once. They should resolve all the problems at once. They could power SATA SSd from the mobo easily with the data cable. For HDD, which is a legacy drive these days, they could add the power from regular PSU SATA cable.
yeah they did... they kept adding 4.... thats after they changed from AT to ATX standard.
So before it was AT where the power switch was directly on the PSU...
Then it changed to ATX where the board now has a momentary switch.
Then the 20pin got upgraded to 24!
The 4 pin also got upgraded to 8 pin because people be ramping up those Q6600 to 1.5V.
The Introduction of PCI-E and PCI-E cards also made PSU's bring out the 6 and 8 pin...
At the very least, its a lot better how long it took to go from HDD -> SSD.
Motherboards already had DC-DC for CPU and chipsets.
These are all on THIN-ITX setups using low wattage CPU's.
Lets put massive DC to DC components inside per say a TRX3 board, and see what hell / havok that can unleash when the 12V rail is pushing well close to 50A though it..
