Hey guys
you were all really helpful when helping me put together my main rig that I want to ask for your input on my first HTPC build. I have wanted to do this for many years but never really had the time. Since I just upgraded and I have some parts left over I figured I might be able to use them. TIA for your input!
I guess a better question....is it worth it trying to build an HTPC using the parts listed below?
1. What YOUR PC will be used for. HTPC, no HDTV yet, but would like to eventually be able to play 1080p video
2. What YOUR budget is. somewhere in the 300$ ballpark, if that is at all possible
3. What country YOU will be buying YOUR parts from. USA, will mostly have to be used parts if it is worth using the parts listed below
4. IF YOU have a brand preference. no preference, though I would like to use my opty 165
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
CPU - Opteron 165
Ram - 2x1gb kingston ktm-m50 DDR400, 1x1gb Kingston KTD8300.1G DDR400, 2x512mb corsair value select ddr400, some combination of those sticks
PSU - Thermaltake TR2-430w PSU
6. IF YOU have searched and/or read similar threads. I have not sorry =X
7. IF YOU plan on overclocking or run the system at default speeds. whatever you guys recommend, would like to stay around stock if the opty can handle it, but willing to OC to a point, just want it to be quiet if additional cooling is necessary
8. What resolution YOU plan on gaming with. no gaming, got my main rig for that
9. WHEN do you plan to build it? over the next couple months
Let me know if this is at all feasible with the hardware I listed
Again, thanks for all your input!!
CPU - Opteron 165
