-I am looking at building a new HTPC. I've never built a HTPC before but I have built and worked on PCs before.
-I will mainly use it for watching Xvid and HDTV from the hard drive, some DVDs(SD), and some occasional gaming. I also want to put all my music on it so I can play it on my home theater speaker system.
-I need to hook it up to my projector and to my CRT TV. I'll hook it up to the projector through my receiver using component. I'll then need another output to the CRT TV of either composite or s-video. What is the best way to accomplish this? Should I get two video cards or do some cards do both component and either composite or svideo at the same time? Most video cards have an HDTV dongle the comes out of the s-video slot meaning you can only use one or the other.
-What is the best software/OS to use to browse my media files? I was thinking about Windows XP Media Center but it is a little pricey.
-Want to keep the cost below $500.
Here's what I have been looking at:
.........................Processor.............................
Pentium D 805 2.66ghz x2 + GIGABYTE 775 Intel 945GZ Micro ATX Intel Motherboard
$121
......................RAM..........................................
Kingston ValueRAM 1GB (2 x 512MB) 240-Pin DDR2 SDRAM DDR2 533 (PC2 4200) Retail
$80
......................Case/PSU.......................................
POWMAX CP808PL-1 Beige Steel ATX Mid Tower Computer Case 450W Power Supply - Retail
$26
......................Video Card......................................
ASUS EN7300GS/HTD/128 GeForce 7300GS 64-bit GDDR2 PCI Express x16 Retail
$60
Another card that I might be able to use only for svideo out
DIAMOND Stealth S60PCI Radeon 7000 32MB DDR PCI Video Card - Retail
$28
.......................Hard Drive.................................
SAMSUNG SpinPoint T Series HD300LD 300GB 7200 RPM 8MB Cache IDE Ultra ATA100 Hard Drive - OEM
$94
......................Windows...................................
Microsoft Windows XP Media Center Edition 2005 (Full Version) Single-Pack OEM
$110
Some wireless mouse/keyboard about $20
Total comes to $540.
Is there anyplace where I can cut back? Is the processor overkill? Too much RAM?
$121
$80
$26
$60
$28
$94
$110
